Cletis,
My confusion is around the different flashers. The wire harness has two 2-pin flashers and the switch shows wiring for one 3-pin flasher. Not knowing what the switch diagram is referring to when it labels one of the pins "pilot light", I can't make a guess about what that pin is supposed to be connected to in the wire harness. The other connections on the flasher are understandable. Also, will I have to connect the leads from both flashers to the same points on the switch?
It's good to know that the brake lights are supposed to be wired through the switch. I wouldn't have guessed that was the case. Thanks for that verification.
I'm sorry if this is beginner level stuff, but that's what I am. Just trying to figure it all out.
