| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | When I used a drill motor to spin the oil pump it would produce 15lbs of oil pressure. The motor was too far gone to ever hope of getting it running. Very little compression. I could squirt wd40 thru the line so I a pretty sure it was not plugged. If I replace the oil line and install the oil distributor with a new oil pump, should I be able to get flow spinning the oil pump thru the distributor hole? The engine has been completely rebuilt up to installing the oil pump, etc. Thanks for your help! | | |
