| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The purpose of the oil distributor is to restrict oil flow to the upper end of the engine until the main bearings and rod dipper fill tubes receive at least 15 PSI of oil pressure. An engine with badly worn main and/or cam bearings will never make enough pressure to overcome the oil distributor spring, so it cuts off oil to the top end to prevent seizing up the crankshaft. A splash-oiler 235 I tore down some time ago had the same type of sleeve around the spring.
Have you checked the supply tube that runs diagonally through the water jacket to see if it's restricted? Jerry
