They're quite different trucks underneath starting with the frame and everything under it, and if you have a 3 speed the 1 ton has a 4 speed, another difference.
It's really not worth trying to make one into another, the result will never be same as what you're trying to imitate. Short of swapping 1/2 ton cab and front clip only over to the 3800 chassis and bed.
•1952 Chevrolet 3800 pickup
---All pictures---
