Replaced the Flasher with one made in the USA. Problem solved. Lights work as they should. Not a loud "click" but that is OK.
Harold
Glad it worked out. It does seem like the "click" on mine has gotten a bit softer. Either that or my hearing has lessened another notch.
I recall amplifiers for turn signal relays, wonder if they're still available....
