10 members (52Carl, Canadian Dump, Gray_Ghost, KEVINSKI, Otto Skorzeny, Southerntruck, Gdads51, BC59, Peggy M, papas52),
177
2
Mod | | | Forums66 Topics128,165 Posts1,057,006 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | At idle you shouldn't have vacuum pulling on the advance. Sounds like the timing is slightly slow to start with.
If the engine is backfiring that might be one reason the vacuum advances are dying so quickly.
But on start up and at idle there shouldn't be a vacuum advance. So double check the timing.
A lot of these engines didn't even run a vacuum advance in the heavier trucks. Just depended on the mechanical advance in the distributor. | | | |
Entire Thread
2nd vacuum advance unit fail in 16K miles,,,,
| Volfandt | 02/20/2017 2:29 AM |
Re: 2nd vacuum advance unit fail in 16K miles,,,,
| 52Carl | 02/20/2017 2:33 AM |
| Hotrod Lincoln | 02/20/2017 2:52 AM |
| JW51 | 02/20/2017 8:02 PM |
| Volfandt | 02/21/2017 4:27 AM |
| showkey | 02/21/2017 2:54 PM |
| Volfandt | 02/21/2017 5:02 PM |
| Skooter | 02/21/2017 3:48 PM |
| Hotrod Lincoln | 02/21/2017 5:25 PM |
| Wrenchbender Ret. | 02/21/2017 6:27 PM |
| 52Carl | 02/22/2017 2:10 AM |
| Roy Rodgers | 02/22/2017 4:35 AM |
| Volfandt | 02/22/2017 11:17 PM |
| Hotrod Lincoln | 02/23/2017 3:01 AM | |
