Here is the Speedi Sleeve catalog.
http://www.skf.com/binary/26-128020/11337_2-EN-SKF-Speedi-Sleeve.pdf
If you know the seal part number and can look up the ID you can get real close just looking for that diameter in the catalog link above.
Be smart to actually measure the shaft and confirm before ordering. In my experience NAPA can order the sleeves as needed, you may have a bearing supplier near by or better source?
•1952 Chevrolet 3800 pickup
---All pictures---
