| | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Are you referring to the spindle section of the axle that pivots for steering? If so, approximately how big a lathe would be required to turn the part after welding? Welding and re-machining the part is a fairly simple procedure, but the only lathe I have in operation at the moment is limited to a 12" swing. Jerry
