A 9" tread width would convert to a 230 MM tread on a metric designation tire. Here's the way the metric tire numbers are translated:
255: tread width in MM's (approximately 10")
70: Aspect ratio- - -the sidewall height is 70% of the tread width, slightly shorter profile than the original tire which was probably around 80%.
22.5: rim diameter in inches.
