| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Get ready for a flood of coolant in the cab. That 1950-something heater core isn't going to play well with the 15+ PSI cooling system pressure of the 4.3 L engine. Either drop the radiator cap pressure down to 7 PSI, or rebuild the heater with a modern core designed for today's pressures. A lot of the S-10's had a hose nipple built into one of the radiator tanks for the heater return line. Jerry
