Thank you Jerry,
Sorry about that. There is 14V at the BAT and at ARM. I ran a wire from the BAT side of the volt reg to the starter. There is 14V at the wire I ran but when I attach to the starter and check the battery it is still showing 11 volts.
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
