2 members (52Carl, Gdads51),
37
3
Mod | | | Forums66 Topics128,180 Posts1,057,161 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | pull the rear cover to drain. There should be a fill plug on the rear cover, right about in the middle, a bit to the driver side. Fill to the bottom of that plug. Online manual says it holds 16 pints. http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0457.htm | | | |
Entire Thread
Drain, clean and fill 2-ton, 2-speed axle
| LewyBoys | 02/09/2017 2:13 AM |
Re: Drain, clean and fill 2-ton, 2-speed axle
| 69Cuda | 02/09/2017 2:41 AM |
| EdPruss | 02/09/2017 1:38 PM |
| mechanic58 | 02/09/2017 6:35 PM |
| Grigg | 02/09/2017 7:26 PM |
| Jim Sears | 02/09/2017 9:19 PM |
| Hotrod Lincoln | 02/12/2017 7:32 PM |
| LewyBoys | 02/15/2017 8:03 PM | |
