9 members (cmayna, Nick in Manitou, Hanks custodian, RdsLessTaken, homer52, Gdads51, mick53, kurbside bolter, 1 invisible),
79
2
Mod | | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hello List,
I have to believe this issue has been discussed to death but the search engine didn’t quite find what I was looking for. I must replace the plug wires on my 55 first series (stock 235 engine and still 6 volts) . The plug wires that Jim Carter sells are carbon core instead of metal core, same with Autozone. I know from working on antique motorcycles that carbon core wires have much higher impedance than metal core and the spark you get is much less robust. So, is it ok to use carbon core wires on these old engines or is it best to look for the old style metal core? Thank you!
Joe
1955 First Series 3100
