7 members (55shaker, crenwelge, Gray_Ghost, JW51, Cosmo, Lostbuthaulinass, Hugh63c10),
226
2
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 3,599 Moderator | | Moderator Joined: Aug 2001 Posts: 3,599 | For an old vehicle with questionable fuel tank and fuel pump. I use a one gallon pump up weed sprayer. Make sure the gas tank is disconnected from the fuel pump and then clamp in the pump sprayer directly to the carb. Do Not Pump the sprayer very much! It may blow gas past the needle valve, flood the engine and leak gas out on the exhaust manifold.
Also have a heavy rag and fire extinguisher, just in case something does not go as planned.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
