I would assume that the under floor brake booster would be the culprit. With your manual, the clutch pedal would likely "be in the way" of the brake boaster and you would have to heavily modify the clutch pedal to make it work with the booster. I haven't done this install but am curious as I may be doing it down the road in my 1/2 ton as well.
