quote=Hotrod Lincoln
It also raises the octane rating of unleaded gas about 5 points by increasing the specific gravity and slowing down the burn rate a little. Before an idiot assistant principal trashed all my dyno run files, I had lots of documentation on the diesel trick.
Interesting, I do have a source for and use no-ethanol gas, the octane is fine for the 51 216, however the 70 Duster with original spec 10.5 ratio 340 is less happy with it. Having diesel tractors and a Cummins Dodge that's an easy fuel fix for the Duster. What about smoke, any noticeable issues?
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear
1970 340 Duster
1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain)
1964 CJ5
