0 members (),
151
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Do you have the specification card on the cam that's in your engine? The most economical cruise RPM will be just slightly above the torque peak. If you get it lugged down too far, the power valve in the carb will open up and kill your gas mileage, plus the acceleration will suck until you struggle up to the RPM where the engine starts making usable torque. Try running a vacuum gauge and see which size tire allows you to accelerate in top gear with the least amount of vacuum drop. Jerry
