0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have found that a lot of the replacement Huck shoes have too thick of lining. You may need to have a little of the lining removed at a brake shop. I usually use the thicker shoes on the front as there is no e'brake linkage there and this allows them to fit. I will then use good used on the rear if I have them.
See the USA in your vintage Chevrolet! My Blog | | |
