Sorry for being vague .Yes that is the panel I have but a little taller. The rust is mostly around the the hole where the hinge goes. It would be nice to just cut around that area and overlay the panel. the rest of the area is strong, no rust. No air die grinder, have a sawsall and a elect angle grinder. I think I will try cutting out a small area and see if that will work. can always make the hole bigger or remove the panel.
