0 members (),
136
3
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | That's not uncommon for one to move with the drum off. If you apply a force to the shoe that moves the other will then move. This is because the spring are not exactly the same tension.
14 clicks seem like to much to me. Maybe 4 clicks or until it just drags. I always tighten till the wheel does not turn easily and then back off till it just drags count the clicks and do the same for the other side | | |
