7 members (HandyAndy, Tiny, TUTS 59, Southerntruck, 66flea, klhansen, 1 invisible),
88
2
Mod | | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Take a close look at the press setup in the pic you posted. I can see at least four squared-off corners that will create nicks and stress risers during the bending procedure that could, and probably will result in a catastrophic failure of the part that's being bent. I'd be very reluctant to take advice from anyone so irresponsible as to advise that sort of procedure, let alone publish a picture of it. That pic would be an ambulance chaser's gravy train in a lawsuit! Jerry
