| | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The 55 6 cylinder with the pivot on the bellhousing is similar to AD trucks and a one year only for TF trucks. The 55 V-8 trucks and all subsequent 6 cylinder trucks used a different set up. The later configuration is as follows: The shifter box has a dog leg to clear the left exhaust manifold. The side cover is different as both shift levers are pointed downward and slightly forward. There is no similarity with the 55 side cover as the long shifter shaft is on the 2-3 on the 6 cyl version and it is on the 1-R on the V-8 version. The 2-3 shift rod is one piece. The clamps that connect the shift rods to the shifter box are different. There is no change on the 1-R shift rod. My suggestion would be to obtain the complete linkage conversion from a newer truck and to get the correct side cover. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
