the urethane is more durable than the old enamels they both spray about the same and the run factor is about the same.are you using a solid color.it is easier to sand runs and orange peel out of solid colors but be careful not to burn the paint while buffing it.honestly the bc/cc is much easier to spray and much more forgiving
The crew that works on the \'42 --Sara, Hannah and Abby
