1 members (homer52),
118
6
Mod | | | Forums66 Topics128,281 Posts1,058,469 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Discovered today the switch is likely incorrect for the '46. Found a photo online that matches it and is described as for a 1950 Buick. Found a 1950 Buick wiring diagram on line and it shows a wiring setup that matches the lugs on this one. Better still it also shows which lug is used for which device. Problem may be solved. | | |
