| | | Forums66 Topics128,247 Posts1,057,902 Members48,477 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, you should use a 12v starter on a 12v flywheel (which has 168 teeth) and a 6v starter on a 6v flywheel (which has 139 teeth).
Just to confuse you, it is possible to use a 6v starter on a 6v flywheel on an engine that was made for a 12v system. You may then run 12v to that 6v starter and the teeth will match/mesh fine (but you should keep your engine well-tuned so that it starts quickly). | | |
