| | | Forums66 Topics128,123 Posts1,056,653 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | The kickdown switch must momentarily short out the ignition to unload the drivetrain and allow the OD to disengage. It sounds like your kickdown switch isn't wired to do that. One of the wires from the kickdown switch needs to connect to the the distributor side of the coil, and I believe the circuit also goes through one of the contacts of the OD relay to prevent the ignition from staying shorted out more than a very brief period of time. Jerry
