I'm trying to use my sandblaster, but am having problems with my air filter. It is a relatively new Craftsman, being used with at 90psi with a relatively low CFM compressor. For the sandblaster, I need every little CFM I can get. Without the filter, the blaster works fine, but it inevitably gets wet and stops working well until it dries out again. I have tried using the filter both off of the compressor, and right in front of the blaster gun, and neither will let past enough air to make it work well. The flow of air is going the right way. I dunno what to do, other than go 20 min at a time, and let it dry out in between. Any Ideas?
Tyler
