Stuart;Thanks for the reply.Yes your emblem is diff in 2 ways,size and mounting.
The 47/53 is usually stamped stainless and the clips are steel but not welded or soldered in,There a slip fit and then crimped.
The2 inner clips are longer than the 2 outer ones.
they actually look similar to a GM rocker moulding mount clip, although 2 different sizes.
Eric;Very good of you to reply also.That definitly leaves me with a few different options and I,ll think about it and get back to you.
I also had thought if I could find a body shop supply and get into one of their catalogs????
Either way You Guys have a great weekend and I,ll talk at ya soon
Regards Steve sr.
