| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I just read: That 30 days should be max. Add fuel stabilizer the day you buy the fuel. The EPA has allowed E15 in some areas. This is no good for motors. E10 was the initial 10% ethanol allowed. Use 87 octane or higher. Due to fuel tanks being vented, the ethanol blend absorbs moisture at a high rate.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
