7 members (Goach2, Dave1234, IHPWR, Hotrod Lincoln, TUTS 59, Peggy M, 1 invisible),
73
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I just pulled my 64 truck dash heater fan control and the pull knob for heat. The speed switch was not working at all. I pulled the switch apart and was surprise to see the contacts coated with what I thought was a conductive grease. Then I realized what it was. It was a glob of graphite. Someone tried to lube the pull cable at the knob end of the cable. It lubed the switch instead. Got it cleaned up and working correctly. If your heat cable is tight, figure out a different way to lube it.
Entire Thread
Heads up on truck with heater speed switch and heat control.
| beltfed | 09/04/2016 3:20 AM | |
