| | | Forums66 Topics128,157 Posts1,056,872 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The housing will pull off once the snap ring is expanded, but you risk loosing the roller bearings at the front of the shaft if you pull the shaft back to much. 1/2" is likely to be to much. I would at the very least pull the side cover so you can watch to be sure the roller bearings do not fall out.
See the USA in your vintage Chevrolet! My Blog | | |
