8 members (Southerntruck, Jon G, GMCJammer51, 3800GUY, Bill Hanlon, Otto Skorzeny, 2-Ton, 50Chevy3100),
157
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,102 Posts1,056,185 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | You would be better off to carry: 1) A set of points and condenser, and the appropriate screws. 2) Feeler gauge 3) The plastic insulator for the original distributor wire. (Removed when installing Pertronix.) 4) The special tool for tightening the nut on that plastic insulator. 5) A new coil. (If you leave the key on without running the engine, you will fry the Pertronix module and melt the end off of your coil. 6) A new ballast resister, and all of the wires necessary to assemble it all (the Pertonix wiring is different).
I may have a better option. Run a points setup in the distributor, and keep the Pertronix in the glove box in case the points fail you on the road. I expect that the Pertronix will spend a very long time in reserve in that glove box. I am not basing this on what I learned while in my easy chair. I learned it the hard way. Fortunately it happened in front of my house, and didn't catch on fire. Carl
Entire Thread
Pertronix installed, do a mess with timing, etc.?
| beltfed | 08/28/2016 1:29 PM |
Re: Pertronix installed, do a mess with timing, etc.?
| Hotrod Lincoln | 08/28/2016 2:43 PM |
| Roy Rodgers | 08/28/2016 3:09 PM |
| beltfed | 08/28/2016 5:39 PM |
| 52Carl | 08/28/2016 6:22 PM |
| joker | 08/28/2016 7:12 PM | |
