| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | What Jerry said plus. A 12 volt system usually requires a ballast resistor in series with the run circuit (not start). Did you remove this circuit when you went back to 6 volts? Don't know, but it you removed this circuit rather than remove or bypass the resistor, you will have no run circuit.
