| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Definitely a voltage problem, or possibly a dirty ground somewhere. A flasher relies on the proper amount of current flow to make the bimetal circuit breaker inside it heat and cool at the proper speed. You either don't have the proper voltage applied to the flasher, or one or more of the bulbs has a dirty ground, preventing them from drawing the proper current. Do any of the turn signal bulbs burn dimmer than the others? Jerry
