0 members (),
172
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | The most likely problem is corrosion between the battery cable clamps and the battery posts. Disconnect both battery cables and thoroughly clean the battery posts and the inside of the cable clamps, then reassemble everything and tighten the clamps snugly. THEN- - -after everything is tight, coat the cable clamps with Vaseline or wheel bearing grease to slow down further corrosion. DO NOT do what a friend of mine did and grease up everything before reassembly! Jerry
