| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Was working on my bedsides today and noticed a problem with a rear stake pocket I got from JC. The only holes in it besides the hook hole were the ones for the tailgate hinge. On the replacement stake pocket, the holes were 1/4 inch too low, which would make the tailgate hang crooked. They'll need to be welded shut, redrilled and the upper nut welded in place. Good thing I found it before welding it to the bedside, as it would have been harder to fix then. Here's a couple pix of the problem. original stake pocket & hinge holesReplacement stake pocket & hinge holes
