| | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | It is very difficult to align the doors with the weather strip installed. It is also very difficult to put the weather strip on the door while it is installed. A conundrum wrapped in an enigma. It would be best to remove the door to put on the weather strip. I am in the middle of this very process with my painter. We aligned the doors, then drilled holes through the inner door and hinge straps for alignment pins for easy realignment. I will get back to you on whether that works out as planned. Carl
