| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | Not exactly a stoivebolt, but my 1931 Olds will start, run as long as it is primed, then quit. I ve checked the fuel connection at the carb and the fuel pump is working. I can prime the engine with gas or starting fluid and it will fire right away, run a few seconds and stop. The car has not been run in approximately 18 months. I have replaced the rotor button, distributor cap and condenser. I am beginning to think I have a carb problem. The carb is a Stromberg DXR-2.
Any ideas?
Joe D. | | |
