9 members (Chip O, Bill Hanlon, J Lucas, dt235sd, Gdads51, Hotrod Lincoln, tclederman, 2 invisible),
76
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | There are numbers cast into the side of the block above the starter behind the distributor. these will tell you what it is. post them and someone will tell you what you have.
Tommy 59 apache 1/2t 261 short stepside | | |
