7 members (Woodcmiami, Jon G, 2-Ton, Pre '68 Dave, Rusted Nut, 55shaker, Bill Hanlon),
117
2
Mod | | | Forums66 Topics128,109 Posts1,056,260 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Thought someone could use this info before buying a new light switch.
I was having an issue with my lights, dash and headlights. So I pulled the switch and tagged every wire by making a diagram and numbering each terminal on the switch and assigned a numbering system on the switch which would correspond to numbers I would place on a peice of masking tape on the wires so that when I go to hook everything up, everything will work. Did that and then cleaned up the connections real good on the switch and wires. I put everything back as it was and turned on the lights and still no lights. So, I started using my test light and found that power was present at the back terminals on the switch but nothing after the terminals. On looking closer I see that there is a set of points coming off the circuit breaker and I took a piece of light cardboard the thickness of a book of matches and ran ir across the points...and "voila" I had power where I needed it to be....so keep these points in mind before decideing that the switch is bad...could save you some $
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
