7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf),
74
2
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello
Starting to rewire 46 6 volt with a new wiring harness I got from one of the suppliers wiring is not one of my strong point s so I have a couple questions First does the armoured cable from key switch go to the positive on the coil
Next in the harness there is a wire to go from the coil - to the distributor but this is not shown in the wiring diagram in the manual what post on the distributor does it go to points or condenser post or is it not used with the polarity switch
Thanks I appreciate the input | | |
