I'd like to keep my lines behind the engine block if I can.
For the fronts I was thinking of a 'tee' somewhere on the left frame by the MC and near the crossmember. And run one short line to the left hose.
Then from that same 'tee' head back over on the opposite (front) side of the crossmember directly to the right front hose (with maybe no union at all).
And so there will be a line on both sides of the crossmember.
But where to install that 'tee' as it is rather crowded on that side?
Hmm.. perhaps on the crossmember itself? headscratch
I guess I need a bit more input..
