2 members (1955 1 Series, JW51),
59
Mod | | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | The brake was most mysterious, sometimes it worked sometimes not. Looked where the pedal shaft exited through floor, found the guide which was originally 3/4" hole was now a 1" hole and all wallowed out. I cut out a piece of steel drilled 3/4", welded it onto existing worn out plate and all is good. BUT....I found my front brake shoe lining cracked in two places...what causes the brake lining to crack? The drum was not scored and the front shoe was ok just the rear shoe lining was cracked in two places...new brakes going on Tuesday at local brake shop?
Steve
