Here's a Tech Tip.
http://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/Gaskets,
Pumpkin gasket; thin, and cover gasket; thick.
PICTURE Ferl-Pro part numbers RDS 5090 and RDS 5988
I like to use Permatex #2 on most gaskets. Put a little on and spread it about as thin as possible with my finger, flip the gasket and repeat. Don't worry about loosing any when flipping, plenty enough stays on the gasket.
PICTURE Also use the same Permatex on the bolt threads to seal them.
PICTURE If I spread just the right amount on the gasket only the tiniest little bit squeezes out.
PICTURE Also washed and removed any burs from axle and hub and put a new gasket on, Fel-Pro 55350. I didn't use any Permatex on the metal flange gasket because I'm not sure if it is a good idea? Time will tell if I should have. Did use Permatex on the axle flange bolt threads.
