8 members (cmayna, Gdads51, klhansen, Stewart2, 52Carl, Peggy M, baldeagle, Gray_Ghost),
187
2
Mod | | | Forums66 Topics128,165 Posts1,057,006 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | Centering tool? I tried to bench bleed but the fluid just all runs out, leaks out the cheap plastic hose fittings and makes a mess. Keeps leaking until fuid is gone. I am going to go ahead and plumb the lines with the proportioning valve in place until someone can tell me if I need a new master cylinder. I can see a remote reservoir will be a must. Had to remove the transmission cross member to clear the Assembly. Not sure its necessary fut I feel better with the reinforcement. I have an open drive line 4 speed but the T5 is looking appealing | | |
