I use one at the positive supply terminal on the coil and one on the GEN terminal on the regulator. In my case they make a big difference. This is because the AM band where I live is very weak and so the radio operates at near maximum gain. Under these conditions the electrical noise is a much greater factor. I use the same condenser as the one in the distributor.
