I like your responses. I realized later that an oil pressure switch would prevent my carb from being primed after sitting for a while and not help with vapor lock. I also like leaving the mechanical pump active and supplementing it with the electric pump. I have a recommended low pressure pump for a 6 cylinder engine. I will just power it off the ignition switch. Thanks to all.
