| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | The transmission in my 58 2-ton is slipping out of 2nd gear. I am looking for a replacement (assuming I have some parts worn that are not included in a master rebuild kit) My question is, does the SM420 case out of a 1/2 ton have all the mounts for the park brake setup, or was there a difference in the case used on the different tonnage trucks? (I am assuming they are all the same case, and I can just replace the rear yoke with my park brake hub and yoke and bolt the rest of the linkage up. | | |
