| | | Forums66 Topics128,049 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's out of a Chevrolet, the numbers are stamped on the passenger side of the front of the third member, between two of the mounting holes near the axle tube. If you can, you might post a pic of it just in case it isn't a Chevrolet differential. That would make it easier to give an identification and to tell you where to look for numbers for verification.
Bill Burmeister | | |
