Most likely, you have already removed the transmission?
Have you removed the inspection plate/cover under the clutch housing?
It has been a while since I worked on a 47-53: are you unable to drop the clutch-assembly downwards?
Then, drop the flywheel downwards?
Someone with experience will post info.
